What option does not allow manual preheating in the repatier firmware?
On my RepRap printer at home I can manually start heating the bed and the extruder without being in a print job, like if I want to unclog a clogged head o change out the filament. However with my new delta, when I try to preheat manually, the extruder and bed turn themselves off after a few seconds. It seems like it's some type of safety feature since I am having it heat up manually without a defined end goal, like heating up for a print job. If I keep on starting the heater back up every few seconds and get it up to temperature, and then extrude, the heater will stay on. However when I stop extruding, the heater will turn itself back off until I either turn it on again and keep turning it on manually, or start a print job. It heats up and works fine while in a print job, just not in manual control. Is there an option in the repatier configuration that I accidentally hit that I don't have on at home that will cause this issue?
