The laser turns on and flashes at the beginning of each movement and then stays off until the end.
I have a kit RAMPS 1.4 Kit + LCD 12864 Display + Mega 2560 R3 and a laser connected in port
D10.And use latest firmware Repetier published.
How do I correct the following? The laser turns on and flashes at the beginning of each
movement and then stays off until the end...
