repetier firmware does not print anything from SD
Hello
I have repetier firmware 0.98, ramps 1.4 and smartcontroller w/ 128x64 display. When I start printing any g-code files from sd card, the display says that printing in progress, status bar shows printing process (however % changes very quickly) but hotbed doesn't hot, and axis don't move. after couple of minutes display says that 100% completed and steppers went to stand by. If I went to position menu and move axis, or start heating extruder or hotbed, everything is fine. but when I start printing from sd card, the printer doesn't do snything. The issue occurs yesterday. Before that all worked fine.
Can you tell me how I can fix it?
Thanks in advance
Thanks in advance
