autolevel setup help
I have an I3 clone and am trying to setup auto leveling but cant get it to work for the life of me.
Here is my setup:
ramps 1.4
latest repetier firmware (works with no issue without autolevel) built using the configuration tool
capacitive probe that works, connected on z max pins, set in firmware
z min endstop
when i try and auto level, i get a red text dialog that pops up and says something went wrong. using g31 the probe moves up like it should and acts like i think its supposed to.
Any guidance is greatly appreciated
heres my config file:
(i currently have the probe turned off due to it not working correctly)
#define ENDSTOP_Z_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_X_BACK_ON_HOME 2
#define ENDSTOP_Z_BACK_ON_HOME 1
/ #################### Z-Probing #####################
#define Z_PROBE_Z_OFFSET 2
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 0
#define Z_PROBE_PIN ORIG_Z_MAX_PIN
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 100
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 4
#define Z_PROBE_MIN_TEMPERATURE 181
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
Here is my setup:
ramps 1.4
z min endstop
what do i set the endstop to if its going to be used as a probe? electronic?
do the other settings for the probing look fine?
does autolevel need to be turned on, on the lcd for it to work?
Now, when i issue g32 (without the s2, it probes, but slams into the x axis min endstop. This is after running homing on x and y.
When i run m114, it says its probing at x20 y20, when it should be probing at x40 y40. It is basically ignoring the coordinates i set, regardless of where i set them.
any ideas?
at least one headache is gone/mitigated.
The auto level stopped working while printing. So its not moving up and down, but the probe is working and it goes to all points.
the probe is probing all points on the bed, saves, and then it acts like its not using the map it made when it goes to print. autolevel is turned on in the firmware, and in the lcd screen.
i reset the positions to a mostly default position, and then cleared the memory and ran g32 s2. the z axis is not moving (barely, which is good and means my bed is mostly level).
i appreciate the attempt at help and understand troubleshooting over forums isnt as productive as being there.
its great to know you guys are here to help us when we have head scratchers like this.
