Configuration and firmware options in front end - do they actually work ?
edited December 2016 in Repetier-Server
As per my title - documentation mentions uploading a printer configuration. if it means the configuration.h from the FW - then this doesn't work as the upload button stays greyed out......
  • That is not the configuration we are talking about here. We mean the server configuration for your printer so you can copy it to a different server installation and have the identical settings from the start.
    How should the server know what to do with a configuration.h file? That is only a small part of firmware sources and need to be compiled. What is possible is to use the firmware uploader form server to upload a compiled firmware as described in documentation. But here also you need to compile yourself first and then upload the new binary you just compiled.
