Upload to sd card via repetier host gets a 0 byte file size?
Hello
I have problems when uploading files to the sd card via windows repetier host, It gets send to the sd card but is reported as a 0 byte file, the only way I could send gcode is opening the file with repetier and choosing upload current gcode.
Also some times I send a new gcode to print gets uploaded and when I start to print the printer make the last file that was printed.
I'm using a kossel mini with a ramps1.4 & arduino mega and it's connected via usb cable.
The solution is simple: don't use "Upload external file". Just load your gcode into Repetier host and use "Upload current gcode" instead.
