E3D BigBox
2»
  • I need some advice. I need to level the two Z axis before doing G32 and G33.
    My initial thought are:
    G28
    G32 S2
    G33
    But this should only be performed when I have reason to believe its off. How should I do the daily/between prints homing? Maybe G28 and a G30?
    Setup:
    - Dual Z stepper with dual Z max endstops.
    - IR Z-probe with no defined Z min endstop.
    - Homing towards Z max endstop
  • I only use G28 for all printers having autolevel. G32 S2/G33 store everything in eeprom so these data stays active and unless I do some action which might change bed level I see no reason to repeat this procedure.
  • Yes, but what should I do for everyday printing? E.g. in startup GCODE?
    I do a G28 that homes Y min, X min and the dual Z max (Takes a while) and thats it? I should trust the stored Z?
    So my Z-probe should not be used for every print?
    If so I need to do all initial probing at printing temperature.
  • Yes trust it! G32 S2 stores all adjustments needed so G28 has them on next homing as well. Most important thing here is that with z max homing you need
    ENDSTOP_Z_BACK_ON_HOME 2
    so endstops are not hit while moving xy at z max making position invalid.
