clogged extruder
hi i seem to be having a problem with my extruder clogging up, iv built a renkforce rf2000 and have it up and printing nicely. the problem is after a few min of printing my extruder clogs up, i have experimented with different temps, speeds, settings etc. i cant seem to get the right force needed to feed the filament through the extruder i can push it through manually but it clogs up a short while after. any suggestions will be appreciated
thank you
i have a RF1000 in office and from my side of view hotends seem to be not very reliable ( 3 hotends/4Kg Filament ).
Problem is you cannot change thermistor or heater ...
just take a look at the temperature logs to see if it comes from that side .
or may be your extruder is grinding the filament? what about that?
what material , temperatures, speed , nozzle diameter etc?
so please some more informations about that
