Repetier-Server acting strange
First things would not print after a hard shutdown(flipping off the power switch on the pi power supply), I was getting a message saying listJobs not found. When you click print it quickly flashed the loading screen and then it disappeared, no error messages in the GUI I only saw the listJobs thing in the logs. A re-install fixed it, I was in a rush to get it working. After re-installing it printing is working, however in the control screen while printing it no longer follows along and draws lines as the printer is printing, the rendering no longer works just shows a gray box for the picture, you can't see any layers in the preview, and the estimated print time is off(though it always has been). I am not too concerned with the estimated print time as I have yet to tweak the settings to try to bring that into an acceptable range, but the preview options were nice to have and it was pretty cool to watch the lines it was drawing while printing in the control screen. Any advice on where to look?
Things were working fine until I had the listjobs error, then I had to re-install just to get it to print. What do you think caused the listJobs not found error anyway?
