Moving files between servers.
I am running Repetier as a virtual Machine on VMWare eSXI. So far it is working great!
I am thinking though of spinning up a pi image and freeing up some VM resources for something else. Repetier is so resource thrifty that having it on a 32 Core Dual Xeon server is a little overkill, lol. I can use those meager resources elsewhere.
What is the easiest way to transfer the files to the pi server? Just a direct directory copy and drop? Or can I transfer the files between the servers? Maybe share out the directory and map it as an external directory on the pi server? Then moves files and groups?
I know that the groups are saved in a DB file, I made that booboo once already.
Thoughts, suggestions.
  • Easiest is using Repetier-Server Monintor to backup and restore on new server. That takes care of stopping server function sin between.
    Alternatively stop RepetierServer service and copy /var/lib/Repetier-Server folder. If you have pro version deactivate license first as it is hardware bound and reactivate on new destination.
