Support for Ironing
Hi, newer versions of Cura support ironing to improve the appearance of top layers but these settings are not exposed in the Repetier interface.  Assuming Cura Engine does as well is it possible to add support for these settings (or manually enable in config files), or alternately is there a way to call the full version of Cura directly from within Repetier Host in the same way we can with Sli3er and Prusa?  Thanks...
  • No. We use a older curaengine version. All versions after that are incompatible to the solution until then, so that it is not possible to upgrade the curaengine. But PrusaSlicer also supports ironing. And of course you still can print g-codes created with newer cura versions.
