Filament run out sensor not working
I have filament detector sensor installed in my duet 2 wifi and it works perfectly fine while running with duet server,but when i run prints through repetier host,it bypasses the sensor and didn't pause or stops when filament isn't there
  • Does it send any message on out of filament? I'm not aware of one. But even if I think host would not understand it, but if there is one standard message I can add it.
    In  Repetier-Server again you can define any response to be interpreted as out of filament easily and add a pause on it.
