Setting up Raspberry HQ Camera - nothing happens after assigning the camera.
I recently bought and installed Repetier on my raspberry Pi 4 Model B.
Along with the raspberry, I also have the HQ Raspberry camera which I used on octoprint in the past (on the same raspberry, I just switched SD cards).
I now am trying to set up the camera for my Prusa I3 mk3s+ but when I select the "Pi camera" in the list of available camera's and click on assign. I see nothing happening.
I tried running taom -f /var/log/messages in a shell and I do see some settings there changing when I click on assign but I never worked with this before so I'm not really sure how the output should look like.
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: Starting Camera
May 11 21:36:17 RepetierServer MJPG-streamer [3979]: Starting Camera
May 11 21:36:26 RepetierServer MJPG-streamer [4171]: starting application
May 11 21:36:26 RepetierServer MJPG-streamer [4171]: enabling daemon mode
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: fps.............: 10
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: resolution........: 1920 x 1080
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: camera parameters..............:#012
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: HTTP TCP port........: 9000
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: HTTP Listen Address..: (null)
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: username:password....: disabled
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: commands.............: enabled
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: starting input plugin /usr/local/lib/mjpg-streamer/input_raspicam.so
May 11 21:36:26 RepetierServer MJPG-streamer [4173]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
I'm running Repetier server pro 1.3.0
Any tips or advice would be much appreciated!
Kind regards,
Pieter
Kind regards,
Pieter
also can you acces webcam on http://ipOfPi:9000 which is the url of mjpg streamer. If that works it is just bad configuration in the server config of the printer. If it does not appear mjpg_streamer has stopped after starting for some reason and we would need to check that way.
