Problems with Waveshare 10.1 Inch (H) Display + Rpi4
Hello Guys!
im struggling now for days to get the Touchscreen working...
Setup:
-Raspberry Pi4, 64gb SD Card (Powersupply is good)
-Waveshare 10.1 Inch Display (H) with Case.
First Setup @ config.txt:
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
hdmi_drive=1
hdmi_drive=1
First Problem was: Just the Boot Logo shows up, after some seconds it dissapear, than Black Screen forever.
Than got the Drivers from Waveshare:
Now after the Boot Logo i have a Console. But nothing happens, beside the console Logs.
It stops at "Started: Update UTMP about System RunLevel Changes"
i tried your posted solution:
sudo nano /usr/share/X11/xorg.conf.d/99-fbturbo.conf Section "Device" Identifier "mhs35" Driver "fbdev" Option "fbdev" "/dev/fb1"
My Output is this:
Section "Device" Identifier "Allwinner A10/A13 FBDEV" Driver "fbturbo" Option "fbdev" "/dev/fb1" <--changed from fb0 to fb1
Option "SwapbuffersWait" "true"
EndSection
This solution does nothing...
Could anybody could help me?
I would really like to test your RepetierServer.
We want to use it in our company, and buy a license after our try.
Looks much more promising as Octo or others..
Thanks!
Does it log in automatically or not? Our system is configured I think that you need pi user to login automatically. Some actions can disable that behaviour.
Login to console and run
sudo raspi-config
It is in boot-options->Desktop /Cli selectable.
Otherwise login in console and send
startx
manually and see if you get any error messages.
I assume you are using our image plus extra action to install the waveshare frame buffer driver.
/usr/local/Repetier-Setup/bin/runAtBoot
It check if $RUN_CHROME is enabled in /boot/repetier-image-setup.txt and if so it starts xserver with
xinit -- -nocursor 2> /dev/null > /dev/null &
This omits all messages, so to test with getting errors you need
xinit -- -nocursor
and you will see where it wents wrong.
We use openbox to reduce memory usage. No auto login is required with current images - that was apperently only the old way.
So please check xinit above and hope you get no "Exec format error". This means that some executeable is not for your processor or os. Could be that you installed wrong waveshare driver meant for a different os/processor.
Access is only required for activation.
You might want to also white list http://download.repetier-server.com which is used to check for updates and autoupdater to download it. Without this you can also always manually download and run installer like for first install - it will just make it an upgrade as it will not change already installed configs/data - only upgrade to latest format if required.
