Random print pausing and fails - multiple machines on Pi4 - CR6SE / Kingroon kp3s
Hi all - been looking for threads on random stop-starting and also just stopping mid print but maybe I don't know what the correct term is?
I've been using 4x cr6se and a prusa mini on one PI with no problems for a while - I recently tried to add two Kingroon KP3s (which I love!) in place of the prusa, but even with only one CR6 and one KR running I get completely random stalls (ie.e moves reduce to roughly every 3 secs, leaving large blobs/burns on prints), or the whole system just freezes (all printers stop but stay heated - I am forced to abandon all prints manually (as Repetier does not respond).
It's all very weird! I can control all 6 printers at the same time in terms of movement and heat - but it's when I start to print it all goes wrong.
For ref the Kingroon are running their own firmware which is based on marlin. I was forced to use usb hubs for the CR6 - as for some reason they all have exactly the same identifier - but the hubs do not affect the CR6 at all.
Any help appreciated!
This means linux closed the serial connection to printer. Check /var/log/syslog on same day at same timestamp. Every day linux starts a new syslog to today that error is in /var/log/syslog.0
In syslog you see more information why linux did close the usb port.
