I've a repetier-server pro and I use repetier-server monitor to backup my configuration. It seems that klipper configuration is not save with this tools, i'm wrong ?
Hello. Is your klipper instance installed with our installer? The klipper config will only get included in the backup if it is located in the /var/lib/Repetier-Server/database folder
