Hotend 1 reporting 0, while M105 reports it correctly
M105 reports: Recv:3:11:57.299: ok T:20.0/0.0 T1:20.0/0.0 B:19.5 /0.0 @:0 B@:0 (24)
However, Hotend1 on my IDEX printer running a later version of Marlin 1 reports as 0.0, so I am assuming that the underlying variable needs to be pointed to the right gcode id to report the temperature. Any advice on how I can fix this?
  • T: is active extruder and you only have T1: for second one in output. Normally marlin shows all extruders so also T0: - there was a version where it was wrong a time ago, but think that was V2. Anyhow check for newer version or if you have an option in marlin that prevents the output of all extruders. As long as firmware does not send values we can not show them.
