MMU(2S) - Customizable color sets (3d/2d) view
Hello team,
I have all printers with MMU upgrade, I am printing in color mostly, but also using different materials for printing.
I would like to request customizable color sets (eg 10 sets and each set is fully customizable) and ability to assign them to the Gcode / 3mf file. During the generation of file it should also include the information about color used as well their respective numbers. I am attaching a file with such info (it is just an example, I am not very good in graphics)
https://i.imgur.com/ZXxDYOu.png
For the gcode files we have some plans. We want to introduce color marker so that when they are present, the renderer will use the selected colors from slicing. This will first work with our slicers, but if other slicers add color information readable for the extruders we then want to detect them as well. If none are present, they will of course be rendered with default colors again.
For the upcoming live 3d preview we will most likely use material manager colors when that module is finished, so it shows with colors currently loaded then and would also allow showing a comparison before print to see if colors are ok.
Anyway I think 3MF from the Prusaslicer contains color per model already, so that I thought you can use. At least it works for me when I open 3mf file within Prusaslicer everything is set correctly including colors I set before.
