New Board, old settings connect?
I had to install a new board last night in my printer, it's the exact same make/model/firmware everything. Is there a way to get Repetier server to see it and not loose all the stuff in the older setup, or not have to spend a bunch of time downloading and then resetting up the thing exactly the same?
thanks
  • Sure. You just need to change connection settings in configuration. Most likely just the serial port name has changed if it has same firmware settings.
  • Cool, I'll relook later,.. kinda tried but couldn't find anything that would let me set it up..
