Anycubic Vyper filament sensor
hi i have a problem with filament sensor while im using repetier server, when the filament run out the printer starts to emit a bip noise but in the console i cant see any message and the printer goes on. how can i configure the server to recognize the sensor signal and pause the printing?
im using repetier server 1.3.0 and the firmware of the printer is marlin 2.4.5
thx
thx
It seems that a lot of printers nowadays doesn't report filament runout to the host anymore.
Could you tell me the results from The G-Code command M412?
echo:Filament runout ON
So I would expect it to return "; Host handling ON or OFF" in addition. Only if firmware reports to host we can react on it.
M412 S1 H1
would enable host handling of runout and report it to host. If you have marlin sources you can recompile them with
HOST_ACTION_COMMANDS enabled and then adding M412 S1 H1 to connection commands would enable the sensor.
Alternatively you need a sensor that is e.g. connected with pi gpio pin and query from that as shown in our gpio tuotial on our homepage docs.
Thanks.
Movers and Packers in Bangalore
i found this
now i think i have to remove // to abilitate this functions but when i try to create a .hex with visual studio i dont have eny environment to choose, if i use arduino ide returns several errors, seems im not able to do this things...
//#define HOST_ACTION_COMMANDS
into
I guess. Inside the #if ENABLED you can add further options for hosts like adding prompt support. You could add that as we support prompts as well, but with that feature it is not necessary.
Where can I find the sources? Not really sure what you mean with " i dont have eny environment to choose" - I would have expected if it was configured for vyper already that you just hit the checkbox to compile.
Do you have platformio installed in visual studio code? If so everything normally installs automatically.
i cannot build firmaware after changing the function because visual studio doesnt show me the option i dont know why
with platformio gives me errors and with auto build marlin no option to buildù
platformio seems can not recognize the board in the source code:
https://github.com/ANYCUBIC-3D/Vyper/wiki
i started with it but comfortable is differently. I have original stm32 solution and there as described in docs the board is missing. You need to replace it as described in docs with this
https://github.com/ANYCUBIC-3D/framework-arduinoststm32_vyper
I think and then it should work. No idea why they do not add the missing files to marlin sources as marlin did already for several other boards.
Unknown board ID 'ac_tri_f103re'
i did exactly as the guide tells but it didnt work so i unistalled platformio and installed it again and when i uploaded all the libraries he created a copy of the folder framework-arduinoststm32@"something" i copied the .jason board even in this folder and voilà.
tested the new firmware seems to work but now i've to work on telling the printer what to do when filament runs out. i think ill be back soon.
thx for help
now when the filament runs out the nozzle stop there on the current layer, i want just to move z up from there.
another problem is that when i recover the printing the printer goes in home axis and i dont want that, i want just stay there and restart to printing.
in rescue panel i see some code in "run on connect" and "procedure" maybe i have to change this code but dunno exactly which code i have to put on it.
just remove Z value?
thx
Next is to check you event dependent gcodes in Printer Configuration->G-Codes->Event dependent. There are 3 parts important:
1. "Run on connect"- Here you activate host pausing on runout: M412 S1 H1
2. "Run on pause" - If this is empty print will stop just where head is. Add at least a move to a parking place of your choice - normally such that it is away from print and bed is best accessible and maybe add some retraction to reduce oozing
G92 E0
G1 E-3 F2000
G1 X0 Y200 F12000
3. "Run on continue" - this is executed before the print continues and before server moves head back to last print position. That is where I guess you have homing x and y, also that is sometimes good. Especially if motors got disabled and you might have moved head during filament change. You can of course remove it and home manually if you see you moved head.
The rescue settings have nothing to do with your pause problems. Rescue kicks in when printer looses usb connection or complete system crashes due to power outage. It then offers to continue a print at some position you select.
Recv:10:51:09.675: //action:prompt_end
i click ok and switch to rescue and i can continue the printing
but nozzle still remain there on run out filament
and there is another problem bed and nozzle stop to heating afther filament run out
The prompt command cause the server to show a small dialog that is more or less empty just headline "FilamentRunout T0" - makes not much sense.
//action:paused mean stop job for some reason but do NOT send any extra commands. See
https://reprap.org/wiki/G-code#Action_commands
And since it reference octoprint docs
https://docs.octoprint.org/en/master/features/action_commands.html?highlight=action
This solution is still a firmware controlled filament change just with prompt to host.
I think instead of
//#define HOST_PROMPT_SUPPORT
you have set
in firmware. That added prompt support. Please try disabling prompt support. That way it makes no sense. In an other marlin version I had seen the prompt asking to change filament which made more sense. But doing nothing and allowing nothing except continue is not really useful.
the code in visual studio is this:
