Installation (OFFLINE)
What to do when I get errors installing the soft:
Win setupRepetierHost_2_2_2.exe, aswell -_2_24.exe
Could you please give
me a good advice?
Thanks a lot
Bei der Installation der oben genannten Versionen erhielt ich Fehlermeldungen.
Beim Start auf die Ikone ebenfalls (die wurde auf dem "desk" generiert).
Was kann man tun um erfolgreich diese Software zu installieren (offline natürlich) ?
Scoobydo
Hello, sorry but I only downloaded the prog. from the homepage with my LAPTOP, charged it on an USB-stick and swapped to the PC, I wanted to work with. That PC goes never online!
After on, I started the installation. There is no other choice to make a different installation. The installation went wrong. But now, is there a download anywhere that could realise this installation offline?
Is there an URL that you could tell me that I have to visit to get this download?
https://imgur.com/a/8u15V0T
Hello, thanks a lot.
That’s what I did, but the problem wasn't solved.
I tried to enhance on this place 2 files without success.
What must I do to enhance this 2 files to show you the errors?
https://drive.google.com/file/d/1BO03FzGfcaCF5F0sEjhP1kZrxk8gyF4C/view?usp=sharing
https://drive.google.com/file/d/166zusVlqq3w87VeGf5zDAnFr28RtGbky/view?usp=sharing
Thanks a lot for you help. N.H.
http://www.microsoft.com/en-us/download/details.aspx?id=22
or any newer .NET version and installer will skip this.
I downloaded the prog., but the moment I swapped it on the USB-stick, I got informed, that several part couldn’t be copied, so that way can’t be a success. I have to try another way… Might be that I calibrate with my LAPTOP, but I shall not work with it. I never work online!
Whenever I had to work online, so I had to find another solution.
Thanks a lot for your help.
