Skip one object while print is running
edited February 2022 in Repetier-Server
Hi!
I just printed multiple objects in one go. One of the objects didn't print well but the others did. So I decided to finish the print.
It would be a cool new feature to tell RS while a print is running, that I want a single object of the print not to be finished.
Maybe let us define a deadzone where the printer should not print anything anymore?
This way it wouldn't waste filament on a messed up print but could still finish the other objects.
Also the quality of the other objects is propably better, as no filement is dragged from the failing object.
What do you think?
  • Already implemented for years:-)
    Go to control tab in normal gui and select exclude region and draw the exclude rectangle on the bed.
  • oh man... I'm so blind... thank you!
