Add a column with custom text to the Gcode queue
I print the same objects just in different colors. It would be nice to setup my printqueue so i can add additional text where i can write the color that i need for that print.
  • Own field is too much as rarely used. But I think we could add changing filename so you can just add color after name or whatever you want. You can already if you rename in models before adding.
