Pause after every g-code command
edited February 2022 in Repetier-Server
Hi there,
I've recently updated to Repetier Server 1.2.1 Apollo-3 and are experiencing something strange.
My printer will pause for about 0.5 seconds between G-code commands, so a print takes ages.
It also does this with g-code files I've recently printed without problems on the previous version of Repetier Server.
Does anyone have a clue why this is happening all of a sudden?
  • Check console without any filters - if you don't see it post it.
    You can also try enabling ping pong mode in serial settings. With some printers that is an issue, but if it worked before it might something in communication that printer does not like and gets send and you only see that in communication.
