Tiny Machines Firmware
Is there a trick or something I'm missing to get repetier server to communicate properly with machines running Tiny Machines firmware? I just updated my CR10S Pro V2 to this firmware which works just fine, but when hooking up to my pi running repetier server, it simply keeps restarting the machine over and over and over and over. It worked fine before the update with the stock firmware. BTW, Tiny Machines is Marlin firmware. Thanks!
Otherwise deactivate/delete new printer reactivate old one with known settings and go to console with filters disabled. See if you get any response from firmware and especially any error message. When communication settings are correct and connect fails it is normally due to some misunderstanding during connection not getting an expected response.
