Repetier-server on Raspberry PI 0 W
Hey,
I have Tevo Tarantula with MKS Gen_1 V1.0 mother board form several years, and  I use Repetier Server on an old laptot but I don't have many place around my printer.
I would like know if  I can install Repetier server on Raspberry Pi 0 W.
Thank.
  • Yes, image should still work on it. First start will be slow as it is configured for armhf version, but on startup will detect that it is a pi 0 and replace it with armel version on sd card.
    Success mainly depends on pi 0 having good wifi connection and since it has no ethernet you should not disable the switch to access point mode, otherwise there is no way except editing net config on sd card to configure wifi.
  • Thank for your quick response.
    I will trie to find  Pi 0 W, many shop are back order
  • Actually the newer version should be much better (don't have it). But pi 0 is really low on memory and cpu so you should do no fancy stuff except printing on it. But speed is good enough for printing so no worries here.
