Server with belt printer (iFactory)
Hello, I am interrested to change octopi by repetier, but one question :
I have 2 iFactory One belt printer, can repetier manage belt printers ?
If you set in printer shape the type to z-belt you can select the angle and that will cause 3d renderings to be correct.
I set up all perfectly, i figured out how to revert the screen (because firstly it reverted the screen but not the touchscreen
I just left with one esthetic "problem"
Repetier generate the 3D model preview of the object, but it generate them at 90° angle, is there a way to revert this ? It's just for the style, print work great, here are one exemple :
I cant upload image, but for exemple if i slice a bar like this ← on the preview he will show them in this direction ↑ (the bottom of the object on the belt, facing me on the preview)
And a last question : I tried 3 times to re install the server because SD card problems, I disabled one installation, but not the first one, it will forever count me 1 less installation of the 5 that i brought ? or there was a way to delet them after ? (the SD was formated)
The bed is always xy and z is up, that would be correct as that is the orientation. A bit strange maybe as the printer is more a xz bed, but layers are by xy with increasing z none the less so that is the order we get data.
Regarding installations on sd card don't worry. It should detect it's same pi and if it doesn't for some reason and all licenses are up, just contact our support directly with license number and we fix that.
But I need one single instance for the belt printer, and one for the 1000x1000x1100mm printer,
In any cas I'm sure I will buy more licenses because i love the cool interface
