Repetier 2.2.3 crashes on Ubunto 18.04 LTS
When starting repetierHost 2.2.3 on Ubuntu 18.04.6 LTS
it crashes with:System.IndexOutOfRangeException: Index was outside the bounds of the array.
at System.Windows.Forms.TableLayoutPanel.AdjustWidthsForSpans (System.Int32[,] widths, System.Int32 col, System.Int32 span) [0x00009] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.TableLayoutPanel.GetPreferredSizeCore (System.Drawing.Size proposedSize) [0x002da] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control.GetPreferredSize (System.Drawing.Size proposedSize) [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control.get_PreferredSize () [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control:get_PreferredSize ()
at System.Windows.Forms.Layout.DefaultLayout.GetPreferredControlSize (System.Windows.Forms.Control child) [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Layout.DefaultLayout.LayoutDockedChildren (System.Windows.Forms.Control parent, System.Windows.Forms.Control[] controls) [0x0002b] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Layout.DefaultLayout.Layout (System.Object container, System.Windows.Forms.LayoutEventArgs args) [0x00013] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control.OnLayout (System.Windows.Forms.LayoutEventArgs levent) [0x0007c] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.ScrollableControl.OnLayout (System.Windows.Forms.LayoutEventArgs levent) [0x00013] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control.PerformLayout (System.Windows.Forms.Control affectedControl, System.String affectedProperty) [0x00066] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control.PerformLayout () [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control:PerformLayout ()
at RepetierHost.view.RepetierEditor.InitializeComponent () [0x02857] in <140abfb63f614d33aa241d7573b4b568>:0
at RepetierHost.view.RepetierEditor..ctor () [0x00145] in <140abfb63f614d33aa241d7573b4b568>:0
at (wrapper remoting-invoke-with-check) RepetierHost.view.RepetierEditor:.ctor ()
at RepetierHost.Main..ctor () [0x002fb] in <140abfb63f614d33aa241d7573b4b568>:0
at RepetierHost.Program.Main (System.String[] args) [0x00015] in <140abfb63f614d33aa241d7573b4b568>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.IndexOutOfRangeException: Index was outside the bounds of the array.
I moved $HOME/.mono away so that a new .mono is created but repetierHost 2.2.3 still crashes with the above error.
The older version 2.1.6 just starts fine with the old .mono directory.
Does it stop immediately or when you open a specific tab/form? Which? Looks like it happens with opening the g-code editor but I could open it on app image on Mint 19 which is nearly same age.
appimage is only for 64bit linux.
Unfortunately there is no higher Ubuntu release for 32bit computers and my CPU (Intel Core 2 Duo) does not work with 64bit OS.
This error shows in terminal almost immediately after I run the program. Just silhuette of splash image shows up, then it crashes.
I've tried to delete ~/.mono and subdirectories (at first) without success.
Version 2.1.6 works fine.
I see 18.04 is still supported by mono project with native alternative files for mono 6
https://www.mono-project.com/download/stable/#download-lin
Maybe that is something fixed, as it was working and starting for 64 bit/mono 5. 32 or 64 bit should not make a difference here as it is same binary.
