M117
edited January 2022 in Repetier-Server
I have Repetier Server Pro 1.2.1
I can not see any of my M117 commands on the HDMI display plugged in to the PI, nor in the windows app.
The display does work, and I see all of the rest of the info.
How do I turn these on?
Thanks!
  • M117 is for printer firmware controlled display only. If you want to see a message box in server gui use e.g.
    @info Some message
    They will show until closed. You can also use our dialog boxes so you can make a function that closes previous message if that is what you need.
  • Can you please point me in the right direction for setting up dialog boxes? I would like to close previous messages with a function.
  • Easiest would be to define a function in event "Printer activation" like
    @func replaceableDialog message title
      @dialogHide {{ global.replaceableDialogId }}
      @dialogStart "{{ local.message }}" "{{ local.title }}"
      @dialogShow global.replaceableDialogId
    @endfunc
    On first save deactivate and active printer to run the code so function is known. Then you can call anytime:
    @call replaceableDialog "My Message" "My Title"
    Which deletes the old dialog and opens a new one with latest message so dialogs do not pile up.
