Server Migration
Hi all,
I have a question about migration, I can't find the correct section in the documentation; I have to migrate the server from a Raspberry 3 1Gb installation to a Raspberry 4 8Gb but I don't understand which files I have to move to avoid configuring everything again.
The license is different between the two installations, I have not deactivated the old license.
Thank you.
  • You can make a backup with Repetier-Server Monitor 1.4.2 (use that version as it has some fixes for backup). This also works without license which does not get backed up. So make backup, deactivate on old install. Restore on new image and then activate license.
    Alternative stop server on image and back up everything under /var/lib/Repetier-Server which is actually what backup does. If you made no manual changes that would be all.
