Server Logs
All my printers failed printing last night at the same time. They are all connected to my Raspberry pi running repetier server. I couldnt see anything in the print logs that indicated it failed so im thinking it was the server itself that failed.
Is there a server log for repetier that I could check to see what happened?
  • In logs window you can download active server.log as well. You might also want to check /var/log/syslog of same day to see what happened in linux e.g. disconnected usb due to some reason (happens on pi when voltage drops sometimes).
