Ignore Files With Same Name - Server Monitor
Due to the large amounts of GCode we use and the constant refining, changing and adding new GCode to Repetier, I use a script that just copies all my local Gcode files in to the Server Monitor's Gcode upload directory once I've made changes.
I currently use "Delete Existing Files With Same Name" on Server Monitor, but it puts a massive strain on the repetier server as it will delete and re-upload 600+ new Gcodes every time I do this.
"Keep Existing Files With Same Name" doesn't work because I'll then end up with duplicates.
Is it possible to simply have an "Ignore Files With Same Name" option? At least this way I can manually delete the GCodes i know i want to be updated and not strain the server or end up with duplicates.
An alternative option would be to have Server Monitor not delete the files from it's gcode directory after uploading them to the server. That way I could just make sure the local robocopy script can ingore the files it needs to ignore instead?
Thanks!
Thanks!
What you need is a timestamp in your script. Remember newest file uploaded on last run and just upload files that are newer then that file. Or just touch a file on script end for timestamp so you know which one is newest. Then compare date with that date and upload newer ones. That way only changed files get uploaded.
