Server Seems to Eat my Startup Sequence...
Details...
Prusa/SuperSlicer current version
Win10
JGMaker Artist-D running Community version of Marlin 2.x.x (current build)
Reptetier Server Pro 1.2.0
;StartUp Gcode AutoPark Mode
;Last edited on Nov 13, 2021
M117 StartUp Sequence
M412 S0 ; Get ABL values in S0
M605 S1 ; Make sure in AutoPark
G90 ;Absolute Mode for XYZ specific addressing
G28 ; home all axes
T0
M140 S[first_layer_bed_temperature] ; Start the bed warming
M104 S[first_layer_temperature] T0 ; set nozzle temp for Extruder 1 (left)
M117 PreHeat Started
M190 S[first_layer_bed_temperature] ; set bed temp and wait for the temp to be reached
M109 S[first_layer_temperature] T0 ; set nozzle temp and wait for the temp to be reached
M117 Everything is HOT
T0 ;for the Primary (left) extruder
G1 Z5 F35000 ; Move Z Axis up to avaoid scratches
G92 E0 ;Reset Extruder
M117 Drawing Prime Lines
G1 X10 Y10 Z0.28 F5000.0 ;Move to start position
G1 X10 Y300.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.3 Y300.0 Z0.28 F5000.0 ;Move to side a little (75% of Nozzle)
G1 X10.3 Y10 Z0.28 F1500.0 E30 ;Draw the second line
G1 E29.5 F2700 ; pull back just a touch, brim or skirt will pickup
G92 E0 ; reset extruder0
G1 Z5 F3000 ; Move Z up to prevent scratches
M117 Printing... ; put message on display
In printer server config you can add in replacements that specific commands get replaced, but it is empty by default so only if you entered some replacements there on your own.
And we might add M105 if no autoreport temperatures is available to update temperatures.
What change did you see? Best enable logging so you can see exactly the difference.
