Duet Server compatibile
"Compatible with Duet Control Server 3.4". What does it mean? Nothing I found about it.
Thanks.
  • Some duet board can communicate with spi with the pi and there a software called Duet Control Server does the communication. So to connect with such a solution you need the DCS connector which is now possible. If you connect directly via usb this is not relevant for you.
