Touch Screen
Trying the PI image on Pi 4 with this screen, everything loads up ok, can login remotely and I can see the UI on the touch screen, but screen does not respond to any touch input. Screen works fine when plugged to my PC.
Any ideas ?
  • Hello,
    did you install the needed drivers for this screen and did you followed the installation instructions of the manufacturer?
  • Thank you for the reply, Monitor says plug and play, no driver needed, I will check with the manufacturer.
