Repetier-Server 1.2.0 Display Issues with Single Printer
After upgrading to Repetier Server Pro 1.2.0 (it's running on the official Pi image) I am now having display issues with single printer displays. A server with 4 printers is fine, but the single printer appears to have an issue with setting the width of the boxes in the grid on the main dashboard? Almost looks like a flex* issue, but not sure what you are using for layouts.
https://imgur.com/a/yVwvzjb <-- image of issue
Browser is: Chrome / Vivaldi / Edge (tried all 3) on Windows 10.
Is this also happening with temperature view instead of camera or if you are not printing?
When you add a virtual printer does it get wider?
Can you reload while debug tools are open? Just in case it is a old css causing the error.
Here is my Ender3Max.xml file: https://pastebin.com/qj4eKkDK
