Upload a file to SD CARD when connected to a printer with Repetier-Server
Hi.
Tested on:
Repetier-host version: 1.6.2 and 2.2.2
Repetier-server version: 1.1.2
Repetier-host platform: Windows 10 64bit
Repetier-server platform: Ubuntu Server 18.04.5
3D printer firmware: Repetier
The button for SD CARD uploading is disabled when connected to a printer with repetier-server. The problem doesn't exist when the printer is connected directly with the USB cable.
I tried to workaround the problem by using scripts with M28,M29 commands but scripts have limited length so they don't allow to send long gcode files. Is there any reason why this button is disabled or is it a bug?
Best regards,
Wojciech Nowak
Server trie sport periodical, but when you deactivate printer it stops trying to do so. So all you need is deactivate printer for upload. But since upload is slow anyway, normally the fastest way is to put the sd card to your computer and copy the file directly.
