Connectivity issue with Klipper firmware and SKR Mini E3 v2.0
I am trying to connect to my printer (Voron V0) with the following port: usb-Klipper_stm32f103xe_38FFDA054253383220730557-if00 without success.
Could you please let me know what I am doing wrong and if there is a fix for it.
Using a SKR mini E3 V2.0
Where did it fail?
On which OS did you install Repetier-Server?
May be a prints creen will be more relevant, see below:
A little update. I managed to see the /tmp/printer port and connect (Like here | alternative solution).
Now I am having the message below and thousand of messages telling that the firmware has stopped and I can only send host and shell commands...
Please let me know what I am doing wrong and if there is some documentation for this.
You need to understand we call with klipper daemon via /tmp/printer while klipper needs to install a printer software on your board and connect with that board and that is the serial you enter there. Don't just uncomment - take the path that your board really tells to linux. If only one printer is connected you see it with
ls -l /dev/serial/by-id
Thank you
