Repetier-Server Monitor
I own a paid license for Repetier-Server and I have it activated on two raspberry pi's. Both have been activated, restarted and show as paid and all features work however the Repetier-Server Monitor app says, "License Required - Cannot monitor free instances" for all printers on both raspberry pis. I have tried removing the Repetier-Server Monitor and deleting all files in %appdata% and it still does it, I would appreciate any help, thanks.
The problem seems to come from a cache with old informations. With above solution the data change goes over websocket so can not be cached and I hope it works.
Do both pis have different server UUID? This is important, but if you copy an existing sd you will have identical pis and that makes also problems. UUID can be changed in general settings->connections.
- On the problem server deactivate the license and the reactivate, make sure Repetier-Host Monitor is open and running and configured with that server when you do this (seems to need realtime notifications)
- Reboot the server you just fixed the license on, make sure Repetier-Host Monitor is open and running too
Once I did those steps with Host Monitor open and running it was ok. Thanks!
