M999 error midway through print on daVinci with 80% infill
When I print with low infill (around 40% or lower) I never have issues with my printer. However, when I go up to 80% or higher the printer fails about an hour into the print with the thermistor temperature dropping and the repetier giving an error M999. Its happened around 5 times so far and doesn't seem to be a random issue. It can't be a wire issue because I don't have the issue around any other circumstance besides higher infill. As soon as I drop the infill the problem goes away. Any help would be appreciated.
Matt
Matt
