Accés a distance a repetier server
I can't see the access to my rasbperry pi 3 with repetier server installed on it.
In local 192.168.X.X I have access
From my internet box, I made a redirection with the port 6000(port for example) on my raspberry pi and I have no access when I am in 4G or at my family wifi.
https://gyazo.com/3b6ba61c316ec7d03663eb8597b3d70b
You need define port 80 or 3344 in your redirection in your router to access the webinterface.
What do you mean? Is that a provider or restriction? On which side is the limitation?
In router you have the port on which a service is offered to the internet and which you have to use to reach it from outside along with your global ip. The other one is 80 or 3344 where the router maps the outside port to. These do not need to be identical and no router has a restriction on that port number.
1. What is the IP address of the computer running Reperier Server? Is it 192.1680.0.3
2. Can you access this IPAdress from another computer on the local network, and does it work?
3. What firewalls are on the Repetier Server computer?
4. What type of internet do you have from FREE, is it CG-NAT?
5. What model model do you have?
6. On the modem, what have you made the external port and have you redirected this to the 3344 on the Repetier Server?
7. What IP address are you accessing remotely, it is not your local ip.. on the house network punch into google: what is my ip
8. What happens when you connect to this ipaddress:port?
I simply installed the free dataplicity app on my RPi and then use the URL (turn on the Wormhole as they call it$ it makes for me to access remotely. Works flawlessly and you can skip everything above.
si demain je vais au Etat unis je voudrais pouvoir lancer une impression sur mon imprimante grace a repetier server
donc je doit dire a repetier server que a la place de 3344 sa devient 49150
Mais comment faire pour avoir le https ?
Puis sur l’application sa marche pas comment faire
D’ailleurs quel est la vrai application ?
J’ai plus d’accès avec l’adresse ip local normal ?
What do you mean with last question? With forwarding you get same functions as with direct access from intranet. Server does not even know it is remote access.
