Same IP address showing up on two prusa printers
When i connect my teo Prusa mk3 printers to repetier server via a raspberry pi, the same IP address shows up on the LCD (on the printers). Is this normal...? How can i fix that? Seem like repetier server acts buggy when this is the case
  • Which ip do you see? Are they on the same server? What you see is the primary IP of the pi running the server. When it is not connected and works as access point ip is for all 10.10.10.1 so that would be ok.
  • I think the answer here is that the printer shows the reperier server IP address. I have 3 printers to one server, so all show that servers ip address.
    The printers are USB so they do not have an ip address.
