Running scripts on 2.2.2 host seems to shut off motors
Hello. I just upgraded to 2.2.2 and my delta printer is doing fine. But I use scripts to  move the hot end to different locations for calibrations (simple g1 commands). however, after the upgrade, the scripts cause the motors to be off and manual moves stop working including home. Also at that time, I can not bring up my eeprom settings. I have to disconnect and connect again to get things working again. I  was working with Zmax in EEPROM and Printer height in Host Printer Settings prior to trying to run scripts.
Repetier Host Repetier Firmware on WINDOWS 7
  • OK, Figured it out. It seems 2.2.2 does not like comments in the script using  //. I removed them and everything is back to normal.
  • Semicolon ; is the comment sign for gcode!
