Random Spool Plastic Spool Unload
Hello everyone,
I have a 3d printer with two extruder jets. While printing some test parts, the repetier window freezes randomly without any intended pause, hence stopping the extruder movement in the x and y direction. After that the spool is beeing unloaded violently and I have to press the emergency button. However, once I press the button, the extruder movement is stopped but the printing timer continous to run without any care.
Any idea what could be troubling my software?
I am using only the newest repetier host version with usb cable. Turned off wifi before in order to prevent windows updates from restarting the laptop. I checked the log and no error messages. Nothing is clogged or jammed.
Best regard
Xalagy
Best regard
Xalagy
When you say you press emergency button - is that at printer or the one on host? With absolute positioning if host does not register it, it will send next move of E but due to reset E starts with 0. Something like that can happen if reset is not detected. So main problem is reset not detected.
