Issues with the print after resume button was pressed
Hello everyone,
I am facing a problem which can be described as followed:
I am printing some standardized continous fiber reinforced coupon specimen with PA6 as a matrix in order to generate some material properties via material testing.
Once in a while I need to clean the guide tube for the carbon roving during the print. Therefore I am pressing the pause button to get the cleaning job done. After I press the resume button, the carbonfiber layers are being printed normally as they should.
But once the job switches to the thermolastic extruder, the extruder jet rams onto the heating platform and starts extruding thermoplastic material nonstop. With this issue I am forced to press the emergency button and start the printing job again.
Therefore I would kindly ask you if there is a solution for this problem?
Best regards
Xalagy
Best regards
Xalagy
If you print via Repetier-Server you might have configured server to change output.
Anyhow you need to make an easy example with the error and check commands, see which is causing the problem and then we need to see where it comes from.
