Creality Sermoon D1
I recently received a Creality Sermoon D1 to replace on of the Creality CR-10s I have been using for a while. However, when I connect it to USB it does not show up in the Repetier server like the CR10s did. I tried to go through the add printer wizard and it was unable to detect the printer. Is there a driver or a specific configuration file for the Sermoon D1 that needs to be loaded into Repetier?
  • I figured it out. It was a bad USB cable. After replacing the cable I was able to complete the Add Printer wizard
