static image in touch screen missing + bitrate setting of webcam can cause errors
in Bug Reports
- if both static and dynamic webcam data is enabled its not possible to switch to static image using the touchscreen of raspberry
- max webcam bitrate can be set higher than 1000 via touchscreen of raspberry -> seems the bitrate limit is actually 1000 and the browser webinterface behaves strange
Bitrate has no limit. Just tested 5000 and 50000 as well, no problem to set it. Why do you think limit is 1000 and what do you mean with behaves strange?
Just to be clear - the bitrate is not for the webcam - it is the bitrate for the created video when you make a time lapse. So the values do not change anything in any web interface.
