Smoothieware telnet connection and repetier?
If I connect serial to /dev/ttyACM0, RH works perfectly. If I change to a network connection and tell it the IP address of the smoothieboard and port 23, it appears to work with manual controls operating correctly, but when I start a print it will frequently send a couple of segments to the printer, then pause, either forever or sometimes just a few seconds then start again (drooling ABS while sitting there).
Should talking to the telnet interface work as a networked printer, or is telnet just too weird to operate consistently?
