UI cut off when long filename is used
When you have a file with a long name part of the UI gets hidden so you cant delete objects.
I suggest the name should be abbreviated if it gets too long, or at least then the window scale. There is a horizontal scroll bar but people generally have  much bigger screens than 1200 pixels so I think you should be able to scale that a bit higher to take advantage of wider displays.
Maybe one could customise what columns they want display to save room? For example I dont really need to know the file size or number of lines.
  • There are 2 solutions already. The table is responsive and can be scrolled left/right to see the delete buttons. That is also why it does not get reduced in length or wrapped.
    The other one is select the image view instead of table view. Then the delete button is also visible.
