température repetier host et Ender 3 V2 | repetier host temperature and Ender 3 V2
.bonjour,
je possède une Ender 3 V2. j'ai voulu utiliser cette imprimante avec repetier host mais lorsque je la connecte, les températures nozzle et bed ne se rafraichisse pas dans contrôle manuel. je n'avais encore jamais utiliser cette imprimante dans repetier.
automatic traduction:
I have an Ender 3 V2. I wanted to use this printer with repetier host but when I connect it, the nozzle and
bed temperatures do not refresh in manual control. I had never used this printer in repetier before.
thank you in advance
  • Have you checked in printer settings "Check Extruder and Bed Temperature"?
    Does it have a valid temperature response? You see it in log when we do not understand it as output. There is a firmware doubling the chars in output so T: becomes TT:: which only the next release can understand.
  • voici:
    17: 56: 46.808: L'accès au port 'COM9' est refusé.
    17: 57: 19.128: L'accès au port 'COM5' est refusé.
    17: 57: 46.627: Aucun signal de démarrage détecté - démarrage forcé
    17: 57: 46.676: FIRMWARE_NAME: Marlin Ver 1.0.2 SOURCE_CODE_URL: https: //github.com/MarlinFirmware/Marlin PROTOCOL_VERSION: 1.0 MACHINE_TYPE: Ender-3 V2 EXTRUDER_COUNT: 1 UUID: cede2a2f-41a2-47c47c48-9b12
    17: 57: 46.676: Cap: SERIAL_XON_XOFF: 0
    17: 57: 46.678: Cap: BINARY_FILE_TRANSFER: 0
    17: 57: 46.681: Cap: EEPROM: 1
    17: 57: 46.681: Cap: VOLUMÉTRIQUE: 1
    17: 57: 46.683: Casquette: AUTOREPORT_TEMP: 1
    17: 57: 46.684: Casquette: PROGRÈS: 0
    17: 57: 46.686: Casquette: PRINT_JOB: 1
    17: 57: 46.686: Cap: AUTOLEVEL: 0
    17: 57: 46.689: Casquette: Z_PROBE: 0
    17: 57: 46.692: Cap: LEVELING_DATA: 0
    17: 57: 46.692: Cap: BUILD_PERCENT: 0
    17: 57: 46.695: Cap: SOFTWARE_POWER: 0
    17: 57: 46.697: Cap: TOGGLE_LIGHTS: 0
    17: 57: 46.698: Casquette: CASE_LIGHT_BRIGHTNESS: 0
    17: 57: 46.701: Casquette: EMERGENCY_PARSER: 0
    17: 57: 46.703: Casquette: PROMPT_SUPPORT: 0
    17: 57: 46.706: Casquette: AUTOREPORT_SD_STATUS: 0
    17: 57: 46.709: Cap: PROTECTION_ THERMIQUE: 1
    17: 57: 46.709: Cap: MOTION_MODES: 0
    17: 57: 46.712: Casquette: CHAMBER_TEMPERATURE: 0
    17: 57: 46.717: Erreur: le numéro de ligne n'est pas le dernier numéro de ligne + 1, dernière ligne: 2
    17: 57: 46.717: Renvoyer: 3
    17: 57: 46.737: echo: Commande inconnue: "* 60"
    17: 57: 46.737: Erreur: le numéro de ligne n'est pas le dernier numéro de ligne + 1, dernière ligne: 2
    17: 57: 46.737: Renvoyer: 3
    17: 57: 46.765: X: 0,00 Y: 0,00 Z: 0,00 E: 0,00 Compte X: 0 Y: 0 Z: 0
    17: 57: 46.765: écho: DEBUG: INFO, ERREURS
    17: 57: 46.765: Début de la liste des fichiers
    17: 57: 46.901: CAT-35 ~ 1.GCO 8522491
    17: 57: 46.902: CHIEN-2H ~ 1.GCO 2934972
    17: 57: 46.902: E3E3E3 ~ 1.GCO 506873
    17: 57: 46.905: RENAUL ~ 1.GCO 8480329
    17: 57: 46.908: R_Z_TO ~ 1.GCO 9355927
    17: 57: 46.910: SAGRAD ~ 1.GCO 6721728
    17: 57: 46.911: E3E3E3 ~ 2.GCO 4284851
    17: 57: 46.913: SSD ~ 1.GCO 1149357
    17: 57: 46.916: SAGCUR ~ 1.GCO 39273241
    17: 57: 46.916: BATEAU ~ 1.GCO 12040954
    17: 57: 46.919: TESLA ~ 1.GCO 13853184
    17: 57: 46.922: IEC_62 ~ 1.GCO 14923510
    17: 57: 46.922: SAGRYT ~ 1.GCO 55871871
    17: 57: 46.925: Fin de la liste des fichiers
    17: 57: 46.927: Erreur: incompatibilité de somme de contrôle, dernière ligne: 8
    17: 57: 46.927: Renvoyer: 9
    17: 57: 46.939: echo: Commande inconnue: "M80"
    17: 57: 46.947: écho: DEBUG: INFO, ERREURS
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 127127
    @ :: 127127
    @ :: 127127
    @ :: 127127
    @ :: 127127
    @ :: 127127
    @ :: 127127
    @ :: 127127
    @ :: 127127
    @ :: 127127
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
    @ :: 00
  • Ok looks like you have that problem in firmware. Please change download link to use 2.2.0 version. There it should be fixed. Just do not forget to download final version when it is out.
